timing not advancing with est unplugged
  • timing not advancing with est unplugged
    Base timing is at 9-10, but retards about half a degree when I rev it. The ignition control module isn't that old, but I'm going to try replacing it anyway with a better brand (can't remember what's in it now)
    The timing is around 20 with the est connected and advances when I rev it.
    anything else I should look for that would cause this? The car seems a bit weak at higher rpms, and if I'm not getting enough edvance then thats probably the reason.
    Car is an 89 with a 3.4, MSD 6a, blaster coil, and msd cap and rotor. I'm going to try bypassing the msd box too just in case.
    ummmm...... the timing shouldn't advance if its disconnected, if i remember the way GM ECMs operate, it should actually retard it...
    by disconnecting it, you're essentially throwing it into limp-home mode.
      Agreed. There is nothing wrong. Timing wont move without the ESC.
        Yeah... that was basically the quivalent of limp mode for the ignition, if the ecm ignition control failed.
        - Ben
