Gas odor from FP test port?
  • Gas odor from FP test port?
    Yesterday my '01 Impala (3400) was in the shop because it was running poorly. The problem turned out to be a bad cat converter but as part of the diagnostic process the fuel pressure was tested. Today I noticed a strong gasoline odor when I drove to work, and when I checked under the hood I noticed that it was strongest around the pressure test port and the port was uncapped.
    Does the port have an internal Schrader-style valve that would allow a little bit of vapor to get by? My guess is that the valve actually stops fuel from spewing out while the cap acts as a second-level safety device and vapor barrier. I'll probably go to NAPA at lunch and pick up a rubber or plastic cap to use temporarily until I either retrieve the missing cap from the shop or buy a new one.
    Am I on the right track here? Thanks!
    Brad
    Yes, the port is a schrader valve. Not sure if it would allow vapors to pass. Most likely guess would be that whoever did the maintenance dumped a bit of fuel while connecting/disconnecting the pressure tester and didn't bother to clean it up.
      After driving around a bit at lunch the fitting was wet, so right now it looks like the Schrader valve might not be sealing 100%. I picked up the cap at the shop on the way home this afternoon so hopefully it'll solve the problem.
      For all I know the valve might've been faulty from day one and all this time the cap's been preventing any leaks.
      Brad
        You can replace the valve easily with a tool that costs a couple dollars. I wouldn't suggest just capping it without at least putting teflon tape around it. Flamable and hot materials don't mix nice, ask Brad
          Hmmm...good point.
          GM doesn't sell the cap separately, only as part of a kit that also includes a new valve. $40 or so, but that's a small price to pay compared to replacing an entire car, even if it is just a plain-jane Impala.
          It should be good and dry by morning so I'll keep an eye on it tomorrow.
          Brad
            $40?
            You can buy the tool and a replacement valve for less than 1/2 that It's the same tool/valve as whats in your tire stems, just make sure the oring color is the same. In fact, the valve may be loose, and is fine...
              Heat and flammable liquids equals...
                Brad, naw, that's just the easy way to strip all the insulation off your wiring harness
