95 Beretta 3100 no spark / crank sensor?
  • #16
    OK Im back. Its not looking good.
    All the wiring was correct.
    I removed the oil filer cap and watched the 2 valve springs that you can see down in the hole while my buddy cranked it over. They didnt appear to move so I was like great I got it bad Timing chain. Well I got to the chain and low and belhold? There is nothing wrong with it. Timing marks line up and everything. SO... am I looking at possibly stuck valves or sheared off Cam?
    • #17
      If the springs and rockers never moved as he turned it over then your looking at a broken camshaft most likely.
      • #18
        Unless the rocker nuts are not tight.. Check those with the valve cover off... if that's not the case then yea cam is broke.
        • #19
          Well removed the valve cover today. Cranked it again and only the Intake and exhaust valve for cylinder 2 moved. The Valves for Cylinder 3 and 5 didnt nothing. Broken CAM... SO looking at this thing it doesnt look possible to replace the CAM with the motor in the car so Im looking at 2 options. Remove the engine to replace the cam or just buy a junkyard running engine for $450.00. CAm costs what? $150 - 200? The the gaskets the time etc..
          • #20
            www.car-part.com search around with that. You could put a 3400/newer 2000+ 3100 too if you wanted to. Need an EGR adapter (check the store here at WOTTECH) and a few other minor things, but a newer engine would have more power and less miles.. Just sswap over the injectors and fuel rail so the lb/hr and PSI is the same as before and it'll be fine.
            3400swap.com details a few of the other things like 3 wire CTS, pretty easy to do.
