What are all these o rings and gaskets for?
  • What are all these o rings and gaskets for?
    There are 18 o rings/gaskets counting the group of 6 as 1. 1 and 5 are hard to see because they are almost the same color as the background. I know what most of them are but I would like to know what they all are. Does anyone know what they all are?
    Do we get a prize if we name them all??
      Sounds good to me. Winner gets control of the site. Hope you know what they are!
      Nah im just kidding. I have some ideas so yeah, that sounds fine. Ill think of something to give away.
        i know 8
        scratch that.. 10 of them.
          oil pan, timing cover, rear main, front main, water pump, distributor mounting, distributor tube, water neck, oil filter housing, cam sensor, crank sensor, rear cam seal, oil pump, oil drain plug.
          Not sure what #13 is. (edited) cross main bolt seals
          It appears to be FelPro part # CS9471? I may have one at the shop and could read them off to you, but I'm going from memory here.
          EDIT again:
          one looks like either the dampener/main bearing repair sleeve.
          3 left...
          EDIT: oil low level sender? I know the 3.4 iron head has them, does the 3400?
            FF got most of the ones i knew.. and #5 looks like the lower FPR Oring.. i'd say 3 is the upper FPR Oring and 4 is the fuel line Oring for the rail inlet.
              Yeah, but this is a block gasket set, wouldn't those come in the top end kit?
                Yes I thought it was a FPR o ring as well but the box doesn't say. It has a couple that are just listed as O-Ring. Ill post the box specs soon..
                  Could someone list the names of these with their corrisponding number in the picture? I have the felpro conversion set and am having a hard time figuring out what goes where as it was over a year ago that I tore the engine down.
                    GM stopped using the side main pan bolts on the newer 3400 and 3500's... neither one of my 04 and 05 motors has those side pan seals.
                    Also I've never heard of a rear cam seal... at least not on a 3400 since they have a freeze plug style cap at the end.
                      both my 3500's had seals on the side pan bolts.
                        maybe I'm mistaken and it's just the 3400... Either way the current motor in my car does not have those side pan seals.
                          I have 2 3500's here, and they both have the cross-bolts and rings on them (caps 1,2 and 3). Correct on the cam "freeze plug".
                            pffffffffft. you guys skip the obvious. they are for a motor.
                              I have the same problem. Bought a re-built engine that came with the gaskets they didn't use. I'm wondering what #14 is. A hard plastic washer.
