94 3.1 pcv tube
  • 94 3.1 pcv tube
    i did a head gasket head change and now the car idles erraticly after it warms up.. my question is does the pcv tube where it connects to the intake manifold have a rubber grommet or is it loosely in there?? because it seems to cure my problem when i put pressure on that point.. any input would be appreciated.
    Use a little gasket sealer around it.
    1992 Buick Skylark 2.3L 1996 GrandAm 3100 SFI 1996 Ford E150 Conversion 5.8L
      the tube is probably rock hard by now, you should be able to get a replacement tube from an auto parts place that will seal much better.
        Yes, it has a rubber grommet normally.
