Stripped rocker arm bolt, in need of part #
  • Stripped rocker arm bolt, in need of part #
    Hi,
    Im looking for a part number for the Rocker Arm Bolt for a 2003 3.4L Impala.
    Mine stripped out and I'd like to replace it with new, but I have to retap the head.
    Anyone know if its a Metric or Stanard tap and die I need to use or should I just go with a bigger bolt?
    Just use a Helicoil. You should not need a new stud if you stripped the aluminum threads in the cylinder head.
    The threads are M8X1.25 in that year I believe. But just take the stud to the parts store and pick the correct Helicoil pack.
    A Helicoil thread insert will be stronger than the stock aluminum threads. Aftermarket heads already come with this modification done. So if you feel like it do all the threads.
