Interference Motor?
  • #16
    It depends how much they float versus how much clearance or lack of clearance there is. But at 5600 RPM with a stock cam and springs you will be fine. If you changed out the cam and left the springs you might run into problems.
    • #17
      My 3.4 Trooper had a 2.8 with snapped timing chain when I bought it. Replaced the timing chain and damper and it was fine. I'd imagine these don't have a lot of valve lift stock.
      Probably wouldn't be so lucky with the 3.4 now that it has 1.6:1 rockers!
      Cheers..........ed
      '90 Trooper 3.4 Conversion, bored intake, Holley Big-Bore, 1.6:1 Small Block Chev V8 roller-tipped rocker arms.
      • #18
        So what conclusion did you come to SGR??
        Did you GM techs continue to back you up? Since everyones post here is really just their "Opinions" as you told me...
        • #19
          Stock 3400 with 34k miles. Alignment pin on the cam sheared off, made contact with all exhaust valves, and bent pushrods. ForcedFirebird has/had my heads to prove it
          Best 1/4mile ET - 12.9
          Best 1/4mile MPH - 111
          1997 Ford Ranger Splash
          Daily Driver
          • #20
            Originally posted by 2k1Impala View Post
            And don't forget, they were also in Citations! Doesn't matter that they are non-interference because there is no timing chain in those engines, the cam is geared off the crank. Beautiful setup, actually.
            Kinda sounds like a Jesel
            • #21
              Quick question Loner. Was that under high RPM or standard load?
              And Jon, yes, they continue to "back me up" as you put it. And I never made the "opinion" statement as I recall. You really want to lay off me. Leave the thread as a civilized discussion as it already is.
              • #22
                At the time it was I was lightly leaving a light. A few mins before that I was on the highway cruising/playing around some from about 60-80 but everything was fine till that traffic light...so Id say it happened around 3k rpm or less
                Daily Driver
                • #23
                  The iron duke I had sounded rough I was told it was from slipping timing teeth on the gear. The crank doesn't have many balance counter weights so it shakes like a mofo in upper RPMS. Same exact piston as 350 sbc though!! lol. The mercur 3.0 crank strokes it out and makes it smoother I've heard.
                  • #24
                    Does that really matter?? High load light load or no load, the valves interfered with the pistons, there for making these engines and interference motor.
                    And I don't mean to nack on a anyone that is, but ASE certified techs doesn't mean they know everything... they just know how to take a test as Z26-T's sig says.
                    As I said before all those ASE cert guys at my local stealership didn't think what I was going to do was even possible. They said I CAN'T put 3500 parts on a 3400, OR even run a 97 venture ECM in my 96 Beretta. Now they are stunned when I bring that car in and they see it run/idle.
