What's the worst that could happen if.....
  • What's the worst that could happen if.....
    You pull a stupid and forget to disconnect the scanner prior to engine starting , because you were distracted. I was scanning codes last night. Turned the key off, got distracted talking to the woman, made a few adjustments under the hood and told her to turn the engine on. Was a few minutes before I realized the tester was still connected. I discovered a miss also, last night. Cylinder 3. Plug is carboned up and probably fouled. But I can't , for the life of me, remember if the miss was there before or after I started with the scanner plugged in.
    Car is an '88 Beretta GT with a '90 3.1L.
    That won't mess it up.
    I start my car in scan and code read mode all the time. It still runs the engine just fine :P
      I was pretty sure. My paranoia dictated a 2nd opinion. Thx Issac.
        Done it many times in both the gold car when the 3100 was running as an MPFI, and I have even done it a couple of times to my 1990 Grand Prix STE. Does not hurt anything, but I know that if you do that in a Cutlass Supreme that has the DIGITAL GAUGES CLUSTER, then the tach does not work until after you unplug it, and also, the DIC will display DIAGNOSTIC MODE.
        Taylor
        1998 Lincoln Mark VIII
          my 85 monte was such a pos i left the paper clip in there 24/7 so i could see if a new code popped up
          92 LeBaron Convert: Does it run yet? 03 Silverado 2500HD ecsb 4x4 6.0L: dual 3" in/out race "muffler" 2005 Ford Taurus SE 3.0: DD from california
