3.1 MPFI torque spec sheet for head gasket
  • 3.1 MPFI torque spec sheet for head gasket
    I'm doing my first head gasket replacement, i was wondering if anyone has the torque specs for it? i appreciate it, thanks.
    33 ft. lbs. in sequence,then an additional 1/4 turn in same sequence. Trying to locate a diagram for you. Will post it. Basically you need to start with the head bolt second from the left on the OUTSIDE side of the head and work your way clockwise.
    ***EDIT***
    Screw it,lol. I took a cell phone shot of one from one of my manuals. Hope it's clear enough. Start with number one and then 2,etc. with torque specs above. GL.
      thank you very much i appreciate it.
        NP at all my friend. GL on your work.
