Temp Guage
  • Temp Guage
    Temperature Gauge not working.
    I have a 1991 S10 regular cab 2.8L V6 TBI and the coolant temperature gauge is not working. I used a Haynes manual from Toyota to determine that the gauge will move. By shorting the lead to ground the gauge goes full swing simulating overheating when the ignition is on without starting the engine. I replaced the sensor with an equivalent to GM PN 25036807 and the gauge is still not functioning correctly. After shorting it out the gauge returns to zero with the new sensor connected and remains there even after driving. Any ideas?
    Paul
    do you have an air bubble in your coolant tract?
    is the water pump pumping?
    do you have a wasted connector (check the pins inside)
    wiring ok? (continuity test)
    last, is the sensor you bought prove to be ok? (its based on resistance, check resistance in a pan on the stove, it should rise with temp)
    2012 Chevy Sonic Turbo 6spd
      It would not surprise me one bit that the sensor you bought is junk. I have seen it tons of times. Try getting a Delco one from your dealership.
