Misfiring
  • Misfiring
    ok so i changed the plugs and wires got the coils checked and they are good
    changed the camshaft position sensor and the fuel filter
    could 2 bad crank position sensors be the reason for misfire?
    i got the car scanned and got the crank signal shortened code
    might have a bad ignition module...
    Lorenzo
      i dont think its that but i will get it tested
      coud it be bad crank sensors?
      it only acts up at higher rpms
        Its possible but Unlikely...
        Lorenzo
          well wat else could it be?
            I just finally figured my miss issue, it ended up being a bad fuel injector. Look up the resistance for the injectors you're using and check them out. I had one bad one. good luck
            88 Beretta GT
            69 Corvette
            79 Mustang Ghia
            95 Cutlass Convertible
              aw ima check that out but it mysteriously stop misfiring
