rocker arm and stud Torque specs
  • rocker arm and stud Torque specs
    Hey i have 01 3100 topend, can someone tell me the stud is 47 lbs? and the roller rocker is 18 lb? It is turbo so i want to make sure.... any help apreciated, btw i dont have a 3100 manual...
    dont remember when they changed the stud size but this is from my 99
    Rocker arm bolt 14 N.m (124 lb. in.) plus 30°
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
      sounds right^^^
        i got that from my alldata online so it better be right.
        99 Grand Am GT
          I torqued my 97 lumina's to 25 ft/lbs. then drove it for another two years w/o problems--even after I found out that at 35 ft/lbs the threads in the heads are at the max!. yep! heli-coiled it! i didn't have a way to measure degrees haha oh well!
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
            1 flat = 60 degrees.
            Note that Geldartb said 124 INCH-pounds plus 30 degrees. Not Foot-pounds. There's always some rocket-scientist who confuses these two... resulting in broken parts.
              Who ever tightens their rockers to 124 ft pounds shouldnt be working on a motor....
                damn that reminds me i need an inch pounds torque wrench and a torque wrench that goes higher than 75 ft lbs. at the time that was higher than anything i was doing.
                99 Grand Am GT
                  True enough... but it happens all too often.
                    i you can't torque the rockers to 124 ft/lbs. the threads will strip out waaayy before that. damn aluminum.
                    Andy
                      Hrmmm I always just made them tight... without a torque wrench... never had a problem with mine.
                        Impact gun FTW!
                        I forget what I put mine at but it's what chiltons said and it's just torq and this it, no extra turning. Done it 3 times and no problems.
