Junkyard engine advice
  • Junkyard engine advice
    I want to replace the blown engine in my daily driver but the car itself is not worth the price of an engine rebuild. I'll be getting a running junkyard engine with a 90 day warranty. I don't want to spend much money but I also don't want to waste a good opportunity while I have the engine on the engine stand. Should I just slap the new engine in as-is or would it be well worth the effort to visually inspect/plastigage/replace the rod and main bearings?
    I have to remove the oil pan anyway (2.8L to 3.4L conversion) and I'm already planning to replace the oil pump.
    Thanks in advance,
    Ollopa
    What car/engine combo are we dealing with?
      OK the car is a '90 Trooper and I'm going to replace the blown (as in dead, not forced induction) 2.8L with a '94 or '95 3.4L from a v6 Camaro.
        I always check things out. I bought a replacment 3.4 DOHC for my 1995 Cutlass Supreme that was suppose to be running, but when I was working on it, I noticed something wrong. Turns out it has a broken valve that punched holes in one of the pistons.
        Taylor
        1998 Lincoln Mark VIII
          Correct me if I'm wrong, but it seems like if I'm gonna check the bearings that I might as well just replace them. And if I'm going to replace them, then I should have the crank polished. I'm worried about one thing leading to another and the whole cost of the swap increasing. Are the main and rod bolts reusable after I inspect the bearings?
            You could but check ebay for bearings. They are cheaper there if you can use the stock size bearings. 95 junkyard motor isn't something I would trust without inspection.
              if it were me, id plastiguge, if ok
              visual inspecition of cyl/pistion via spark plug hole and an LED light on a wire int here.
              compression check
              have someone turn key while checking compression
              or get a starter bumper thing (so you can check yourself) the valvetrain
