3100 Cam Angle Sensor Testimonial
  • 3100 Cam Angle Sensor Testimonial
    I ignored the bit of wisdom put forth on this site and purchased a $35 cam angle sensor from Auto Zone. When I started the car after reinstalling the power steering pump and buttoning everything up - it ran worse than before. So I went to the dealer and purchased one for $60 and installed it, and while I was at it, I replaced the brittle plastic emissions pipes. The Delco part worked perfectly, and everything under the hood is much happier.
    Lessons learned:
    1) It wasn't worth $25 to have to do it twice.
    2) Start the car and see how it runs before reattaching messy, fluid filled components!
    Do you mean cam position sensor?
    SpudFiles
    Theopia
    Enjoy life online.
      Different nomenclature for the same part, I guess.
        Thats funny because I'm using an 05 cam sensor on my 96 ECM, with a 01 style cam ring...
          autozone sensors are shit. I bought their Borg Warner coolant temperature sensor, and watched my dash gauge peg to red in a matter of 10 minutes of driving. It was giving an output like 50% high.
          Brian
          3400 SFI V6, 4T60e
            x2
            I put a CPS from Autozone on and less than a year the car starts dying. I think it's the ICM since I *just* replaced the CPS. Well $90 for a new ICM it's doing the same thing. Get a different CPS at ORielly's and it's been fine ever since. Yeah I was mad since now I have 3 different working ICM's, and the CPS is a b*tch to get to.
            A friend mechanic also knows to stay away from Autozone electronics.
