When this Monte Carlo first showed up it had no probs whatsoever. Then it developed the LIM "leak". After replacing the LIM gasket it made it about 40 Miles when the ECM fuse blew. After replaceing the fuse it made it ~100 miles more, croaked again. This time a whole bunch of stuff was acting goofy. Turn signals didnt work well, ABS and traction system sporadically working, you had to hold the brake down for it to start. After tearing the dash apart, determined that the Ignition switch had died. Replaced that, ran fine for about a week. Now it has died again, no comms with the ECM and Trans computer. All fuses fine, good 12V going to engine computer, other computers(ABS/traction, body) fine. Good ground on engine/body. Now nothing out of the engine, no crank, nothing. What the heck is goin on here???
