quick question on 3.1 intake torque sequence
  • quick question on 3.1 intake torque sequence
    In the middle of replacing my lower intake gasket, I have the felpro problem solver kit. Instructions say to " starting with the center bolts, and using a crisscross pattern, torque all bolts to 62 in lb and then 115 in lb. Torque the 4 outer bolts to 18 ft lbs."
    Question is do I tighten ALL the bolts, including the end bolts, to the 61 in lb and then 115 in lb, or do I install the outer bolts hand tight, do the torque sequence on the inners only, and then after they are done tighten the outers to the 18 ft lbs?
    figured it out myself, thanks
