I am gonna try and put a LONG story short. My car stopped starting. I had to use ether to start it. It was a B*TCH to cold-start. But once the car was started in the morning, it only needed one small spray of ether everytime after to start. I thought the fuel pump was shot. Typical GM problem; fuel pump starts going, need ether to cold-start. Fuel SYSTEM is brand new. Take to mechanic, not the problem. Crank Position Sensor is shot. I have it replaced. They say that I still need ether to start, or need to disconnect TPS. They say TPS is shot. Car will never start on it's own. Well, one day it magically started starting on its own. Only problem is, until car is warm, then shut down and restarted right away, car idles at 3k RPM. Then, once warm car idles ok. Occaionally R's drop SUPER low, and car will randomly die when at redlight. Also, on occasion when you depress gas peddle (ALWAYS when cold, SOMETIMES when warm) the car will stutter, almost die, then take off. WTF is going on w/ my 3.1??
Thanks all, if you need further clarification please ask
Matt
EDIT: And if this makes one ounce of difference, the air box is NOT hooked up tight onto the intake. The clamp is missing, allowing a small air-leak.
Matt
