Idle Relearn
    • 13514
    Idle Relearn
    There are a few methods floating around, but this is the one used by GM techs (OBD1 method).
    1. Reset ECM by pulling ECM fuse (underhood) for a few seconds.
    2. With A/C turned off, start car and immediately put it in Drive
      with your foot on the brake. If the car does not start initially,
      keep trying WITHOUT putting your foot on the accelerator.
    3. Let the car idle in gear for at least 5 and no more than 7 minutes.
    4. Shut off the car for 10 seconds.
    5. Start engine, place in drive and let idle for 5 minutes.
    6. Shut off engine.
    7. Idle is learned.
  • 86CamaroGuy
    • Jul 2007
    • 1
    2.8 with a 5spd
    How do I do the idle relearn with a manual transmission? Won't the car stall? Any info would be great. Thanks
