3500 lim gasket options
  • 3500 lim gasket options
    I keep hearing about these problem saver lower intake manifold gaskets, which I think would be ideal for a hybrid turbo setup. I'm having trouble locating a set, though. I'm using a 3100 block with a 3500 head/LIM and a 3400 UIM. My question is this, what are my options for gaskets for the intake manifold gaskets, and where can I get my hands on them??
    Any help is appreciated.
    It\'s Alive!
    It\'s Alive!
    i'm using the GM 3500 LIM gaskets... i don't think there is an aftermarket replacement out yet.
    the 3500 top end shouldn't have the issues that the older stuff did.
    BTW, you can't use the 3500 heads on a 3100, the combustion chambers overlap the cyl walls. you'll probably end up blowing headgaskets left and right.
      GM is the only place to get 3500 LIM gaskets at this point and time.
      2000 Grand Am GT
      2011 Chevy Impala
        IIRC you cant use 3500 heads on a 3100 block due to combustion chamber overlap on the head gasket..... I think you need at least a 3400 block to use 3500 heads...
        Someone correct me if I'm wrong.
          ur right but looks 2 posts up. dave just said the same thing
            Thanks.
            Crap.
            Thanks for the heads up. I never realized that. I guess it's back to the
            3100 heads and intake. I'll have to save the heads and intake for the next engine I'm going to build when I inevitably blow this one.
            Thanks, Chris
            It\'s Alive!
            It\'s Alive!
              Plan B
              Ok, since I am relegated to the old style 3100 intake manifold, what are the part numbers for the problem saver gaskets for the 3100 old style, or maybe a link to buy them online??
              Thanks again, Chris
              It\'s Alive!
              It\'s Alive!
                NO use a 3400 top end, that will fit a 3100 block with 3100 head gaskets.
                Probelm solver gaskets can be found on Autozone's website, or Advance Auto Parts website. I'm not sure on their part numbers.
                  Felpro makes the metal gaskets you want...
                  and yes, use a 3400 top end... and a 3500 plenum.
