89 Beretta GT knock.
  • 89 Beretta GT knock.
    I bought a 89 Beretta GT today for $400. The only reason i got it so cheap is that the previous owner couldn't seem to find the knock in the engine. It has new main and rod bearings, heads redone, and a new timing chain. When the car is started, it makes more of a rattling sound than a knock and the sound disappears after approx. 2000 rpm. Anyone know what this sounds like and what it'd take to fix? I have enough parts to probably build another 2.8 but really don't have the time to spare to do a swap. If it's something simple i'd rather repair the engine thats in the car now and drive it, but with my luck, i'll probably be doing a swap. lol.
    Piston slap? Valvetrain?
    Hell it could even be the tranny. Its hard to tell over the net. Got any vids with sound?
      check the flywheel bolts also... seem to be coming loose alot lately..
        I let the car idle until it was up to temp today and then gave it a little gas and it's definatly a knock and not a rattle and doesn't go away after 2k. I guess where the oil was colder and thicker it made it not sound as bad. How bad is it to pull the engine in the beretta? It looks a bit tighter than my Z24 for some reason. Also, it has a 5sp tranny. I'm thinking of pulling the engine and using the heads off of it and putting on another 3.1 that I have and putting it in the car.
