Still overheating. HELP!!!!
  • #16
    it will take numerous flushes to fully get rid of dex-glue.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    • #17
      Well I bled the air out of my coolant a few times, pretty sure its ok. The problems not as bad but it still overheats a little. Now I noticed that my cooling fans dont work until I shut the car off, wtf??? I have an aftermarket pcm but I never got a case learn, could this be the problem?
      I know my fans were working before while the car is running, but now they dont even with the a/c or anything on.
      • #18
        I had the same problem with a 5.7 once. My T-stat went bad and it would stay stuck closed until about 250 causing it to overheat once and then it would be fine. I bought 2 aftermarket T-stats and they did the exact same thing. Finally I went and bought a GM T-stat and it was fine after that.
