steel cranks??
  • steel cranks??
    any 3.1/3.4's have steel cranks out of curiousity?
    next, what makes a 3.5 a 3.5? is it more bore or stroke than a 3.4? lastly, is the block(more importanty, the crank sensor setup in it for the DIS) still the same on the 3.5's as the earlier 60v6's?
    wow, you really don't read the pushrod section often do you:P The 3500 has a different timing setup, hence the external crank trigger on the store here. No steel cranks in any 3.1 or 3.4. More bore for a 3500 but the crank is also much different as are the rods. Larger diameter everything basically.
      damn, that sux . id say this was my first post ever in the pushrod section.
