IAT Sensor part number
  • IAT Sensor part number
    I'm looking for a part number for a GM metal threaded "screw in" type intake air temp sensor. The kind you would screw into an intake manifold.
    Thanks
    Lyle
    Goto www.acdelco.com and look it up for whatever application you are looking for. If you want an actual GM part instead of an AC Delco, you can goto GM Parts Direct and look it up in their online catalog.
      Need little more help, please
      If I knew the factory application, I would have no problem finding the part, but unfortunatly I don't. Do you happen to know what motors used that type of IAT sensor, it would be very helpful.
      Thanks
        Check out http://www.tomco-inc.com/ They have a number of online catalogs and you will be able to find what you want with OEM part numbers...
        \'83 S10, 3.4 SFI, 4L60E
          I had problems finding that part. They quite making it at the dealer, so I had to buy it from Schucks (kragen, checker, whatever). Have you measured it and confirmed that it is bad?
          89 RS - 3.25L V6
          89 RS - 5.7L LT1
          87 S10 - 2.8 flatbed, RS wheels
            89 RS - 3.25L V6
            89 RS - 5.7L LT1
              GM # 25036751
              Echlin ECHT55100
              Wells 54107
              Borg Warner WT382
              These are the plastic-tipped, threaded body sensors. Threaded sensor with brass tip is 12160244 (I think). Unthreaded plastic part is GM #12160244 (LS-1 F-body).
              You can pick up the other brand sensors at AutoZone, Advance, Napa, etc. Have them look for a '88 Buick Skylark with the 2.5 TBI. I think it is also used on the '87 Fiero V6, and many others.
              Marty
              '99 Z-28 - Weekend Driver
              '84 X-11 - Time and Money Pit
              Quote of the week:
              Originally posted by Aaron
