test drove an Impala - 3400 question
  • test drove an Impala - 3400 question
    i test drove a 2001 base model Impala yesterday. according to the LIM it has a 2000 engine. the sticker in the door jamb says the car was produced 5/01. is it likely the engine has been replaced? or was it produced early enough in 2001 that it just got a leftover 2000 3400 engine?
    thanks
    '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
    '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
    GM W-body Forums
    pre 2000 say 99, 2000+ all say 00 on it until the new 3500 which says 04.
    [SIGPIC]
    12.268@117... 11's to come!
      well i did also look at a 2003 base Impala that had '03' on the LIM.
      GM W-body Forums
        I wouldn't worry about it too much. If you are really worried get a carfax and see if the motor was replaced... I'm sure GM has a stock of motors sitting and puts them in cars until they use up the batch. Then make more. I doubt they build each motor along side each car...
        My 3400 LIM doesn't have a date on it. But that's because it's from a 97 van probably.
          I just saw a '01 Monte on ebay with 00 on the LIM manifold. Also I'm not sure, but I think my sister's '02 GP 3100 has the same "00" numbers on it. Didn't something change in 2003?
          Brian
          3400 SFI V6, 4T60e
            they got coated piston skirts to prevent piston slap, that's it.
              thanks guys sound like something i don't really need to worry about then.
              GM W-body Forums
