I got a thermostat the other day and it looks like it already has a gasket attached to the stat. Do I need the gasket that I bought seperatly or is the gasket on the stat ok? 1989 GP LE. Thanx
the Rubber O-ring seal on the therm and in some cases a Paper gasket for the housing.
gen2 engines use a paper gasket as well IIRC. but Gen3's only use the rubber oring on the therm.
Colin
