Head Cleaning
  • Head Cleaning
    How do i get this brown crap out of my heads its tough as nails,tried varsol,engine cleaner,power washer,maybe it needs heat like engine temperature.
    1995 Cutlass Supreme 3100 SFI
    Cold Air K&N Filter
    58mm TB
    Dynomax Duel Exhaust with Performance Catalytic Converter
    FFP Underdrive Crank Pulley
    1/4 mile 15.65 at 90.8 mph
    You tried soaking in Mineral Spirits or just scrubbing them with carb cleaner?
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
      Just take them to a shop and get them acid cleaned and pressure tested.
        it is probobly just from oil drying on there or carbon build up.
        a high grit grinder should work like a dremel tool just watch what you hit.
        high grit sand paper should work for the flat parts, like 2000 grit or some shit
        Donesic Disurbance
        Grand Am 3400
          Thats oil-soaked aluminum. The only way I know to get rid of it is to sand it down. However, its nto hurting performance, and its covered by your valve covers. Why worry about it?
            a good parts washer will get rid of that crud in an instant.
            Colin
              I have a parts washer with varsol in it and it helps takes that crap off
              but you still have to scrub it quite a bit
              Im doing my 3.1 turbo engine and that crap is everywhere
              cheers
              Dave
                One of the best cleaners I've found is "Spray-9". It worked far better than engine degreaser on some old crud. However, it's a bit hard on the hands. Not sure if it's safe to use around rubber though.
                90 Chev Lumina 3.1 398 000 KMs
                If if works, DON\'T FIX IT.
                  OKay guys i found the cure i tried to use throttle body cleaner didn't work then i got some combustion chamber cleaner man that stuff is harsh but the stuff melted away like butter.Problem solved.Back to nice aluminum.
                  Cold Air K&N Filter
                  58mm TB
                    B-12 from Chemtool.. liquid eraser
                    I modify stuff
                      mine looked worse than that , i took em toa shop and had them hot tanked, look good as new now,15$ a head
                      3.4L camaro some goodies
                        Thats a good price cause the Combustion chamber cleaner is $10 a can.
                        Cold Air K&N Filter
                        58mm TB
