mechanical oil gauge tap
  • mechanical oil gauge tap
    any ideas where the best place to take a line off to the guage would be?
    89z24 2.8L (3.1L hybrid soon) but both similar blocks, oil filter adapter and the cluster guage is off the block because the oil filter adapter doesnt have the provision for it.
    got zap-straps?
    89 Z24
    13.886 @ 96.16 mph
    street trim - slicks
    Well where is your oil pressure sending unit going to be? Tap (with a "T") into that. You need the oil pressure sending unit to run your fuel pump.
      yeah i know about the wiring off that switch, best place is just to T into that eh.. nowhere else on the block?
      got zap-straps?
      89 Z24
      13.886 @ 96.16 mph
        on the back of the block, there should be an oil service port where you may be able to put the sensor. if I remember correctly....
        --Dave.
        Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
