Crankshaft Position Sensor removal on a 2.8
  • Crankshaft Position Sensor removal on a 2.8
    I have a 1989 Beretta with the 2.8 v6 in it and narrowed down my problem (turn over but not start, no spark) to the CPS. Well, I bought a new one, found the old one and went about removing it. It's stuck!!! I went as far as to try and pry it out with a screwdriver and the top came off and all that is left is the cylinder shaped part stuck in the block, pretty much flush with it. I have been told that the reason it's stuck is probably because of carbon build-up on the sensor.
    Has anyone ever run into this before, and if so how can I remove it? I may have to resort to drilling and tapping it so I can put a screw into it and yank it out that way.
    Any suggestions? Thank you.
    RE: Crankshaft Position Sensor removal on a 2.8
    you might have to do it that way. I was very lucky in that the sensor's metal prongs were still there. I put a vise grip on it and pulled straight out. you could try drilling a small hole and screw one of those drywall screws in, or anything "self-tapping" with large threads.
    Brian
    3400 SFI V6, 4T60e
      i believe you can drop the oil pan and get at it that way.
      -Chris
      1992 Chevrolet Lumina Z34 3.4L TDC Getrag 284
      1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
      1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
      1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
        yea you may have to drop the pan and push it up through.
          Actually, I have good news! After a few hours of drilling and chipping the sensor out with a scratch awl, I was able to pull it out. It had split along the side and thus was larger in the crankcase end than the hole I was trying to pull it through. Got the new one in there, and it started right up!
          HUGE pain, but well worth the effort.
            glad to hear it
            Brian
            3400 SFI V6, 4T60e
              Incase anyone comes across this in the future. Try a vacuum cleaner.
              I guess I was too late on this thread.
                i doubt a vaccum cleaner would work, in my experience they really get stuck in there. no vaccum cleaner i ever seen would yank it out.
                -Chris
                  It was in there way to tight to get out with any amount of vacuum
                  BTW, here is the old sensor:
                  You can see at the top where I had to chip away at it, and where it is split along the side. The metal prongs were all I had to grip onto with pliars to pull the stupid thing out!
                    Worked on my Camaro block.
