intake
  • intake
    i got a 2.8 into a fiero and when the engine is cold we can hear the intake a lot wisling!
    it is heard around the t.b.
    i'm running a cone type filter directed into the ram air into the side of the body
    i read somewhere that a throttle body shim with a vortex effect would cure the problem
    if that works wy not a spiral max vortex maker or any competitor ,it shure looks like it will affect the air more than a shim
    any ideas
    stroker
    That sound is normal. If you dont' want that hissing noise then put the stock intake tube and box back on it.
      As was said its completely normal. The stock airbox/intake tube is designed to quiet down the intake so you can't hear that. It sounds good IMO, but if you don't want it, just put your stock intake back on it. I don't know how some spiral thingy would help though.
      Shawn
      99 Grand Prix GT
        i run a cone style filter and love the air sucking noise. it makes the ricers ask me if i have a turbo
          those spiral max and tornado things only work if you have iron heads
          what they are supposed to do is put a spin on incoming air as to help make the fuel charge more homogenous
          if you have aluminum heads the design of the heads already does this so in that case the stay away from putting anything in the path of the incoming air
          I Like V660s
          Does Chevy make beer
          ~Jayme~
            i have a 3 inch tube attached to my airbox that goes down below my bumper and a K&N filter... and i hear it....
            Phisics Note: nothing sucks... its a differnce in atmosphric pressure.
            91\' Mazda miata.
            92\' Lumina (sold)
              I know lots of things that suck!
                actually the weight of the air in the atmosphere surrounding the earth pushes air into the intake because the cylinders create a partial vacuume when the valve is opened
                I Like V660s
                ~Jayme~
                  Spelling Note: Physics
                  Robby Whitesell
                  2006 Pontiac G6 GT
                  1985 Toyota Pickup DLX
