Lean Backfire through TB
  • Lean Backfire through TB
    Hey what's up, I'm new to this board and here is my question.
    I have a 2.8l in my 1988 S10 Blazer and I had the motor redone and had a hotter cam put in it. but it always seems to backfire through the throttle body.
    I have since added MSD coil and wires, Holley 400cfm throttle body, hypertech chip I know I am forgetting more, but I have the reciepts and records of what I've done (it has been a while since I have messed with it --on going project truck)
    any insights would be great, thanks
    http://www.grknss.com/index.html
    1988 S10 Blazer 4X4
    Beatdown Boston Red
    lots o\' Mods
    2004 Subaru WRX STi
    Platinum Silver
    Audio Mods......to say the least
    Most likely a timming issue first thing I'd put a timming light on and see what it's sitting at and double check for crossed wires ect...
      oh yeah, thanks but the timing was in spec. we even tried advancing and retarding it with no real changes.
      1988 S10 Blazer 4X4
      Beatdown Boston Red
      lots o\' Mods
      2004 Subaru WRX STi
      Platinum Silver
        Are you timing with the ESC bypass wire disconnected? Be sure you are or your timing will be severly retarded
          yes timing was done correctly, a friend of mine helped out (he is a GM tech)
          1988 S10 Blazer 4X4
          Beatdown Boston Red
          lots o\' Mods
          2004 Subaru WRX STi
          Platinum Silver
            What did you time it to?
