cam position sensor?
  • cam position sensor?
    does the 3500 cam position sensor work with a 3100 pcm?
    Yes, I've been running one on a 97 pcm since 08
      ok, then mine is most likely bad, which helps to explain why I'm having idle problems to a degree. P0341 lit up while working on it today...
        looks like there's a wiring issue somewhere... damn...
          Did you test from the ecm to the plug for continuity?
            not yet, going to probably tomorrow.
