iron head spring install height
  • iron head spring install height
    Just want to see if this is what it is supposed to be.
    Intake, 1.600" install height. 0.962" min height for retainer to guide
    Exhaust, 1.630" install height. 1.030" min height for retainer to guide.
    The intake side has a clip of some sort on the spring seat, which probably makes it the same as the exhaust side in stock configuration.
    Yes 1.6 sounds right to me. I have the factory service manual for my S-10 if you need more info.
      I always thought it was 1.7
        Newer engines might be. Factory spec for say a 3.4L iron heads is 1.610"
        Aftermarket springs are usually taller.
          via alldata:
          94 camaro 3.4:
          1.91 free length
          1.61 installed length
          80 lbs @ 1.61
          190 lbs @ 1.20
            Cool thanks!
            Sent from my samsung galaxy 107 using Tapatalk 2
