3X00 Thermostat housing
  • 3X00 Thermostat housing
    Looking for a thermostat housing that will work for for a 3500 LIM that is straight. Anyone have any ideas?
    As seen in this picture, the thermostat housing is slightly bent to the driver side, I need it to be a straight shot for my downpipe..
    Cut it and rotate pipe and reweld, Get any angle you want that way, they weld up nice.
      don't you need to tig it?
        Yes you do.
          Reminds me of an episode of STNG... "Sure, all you have to do is change the gravitational constant of the universe..."
          LOL... not everyone has a Miller or Lincoln in the garage.
          - Ben
            cut it, rotate it the way you need it and mark it.. then have a local welding shop weld it back up for like $20.
              did you check and see if CNCguy had one
                The t-stat housing from a 05' equinox is almost straight. (lucky enough one came into work and I had to do something in that area.) It bolted up perfectly and looks sweet! It has a very, very slight curve to the driver's side. It's about 1.5" shorter than the factory 3400 one. However, it does not have a bleeder screw. But I should be able to burp the system just fine without it.
                  Here is what you're talking about. I have this engine in my Fiero.
                    Yep, that's what I have now. It looks a bit better on my engine though .
