65 MM throttle body
  • 65 MM throttle body
    What should i do for a gasket for the 65 MM throttle body? Use gasket maker or try trimming a gasket to fit?
    razor and roll of gasket material. worked on mine. about 10 bucks. autozone or anyone carries it, use paper material.
      I just trimmed a stock 3400 gasket. If you have enough patience itll work.
      3400/Getrag 284 5spd
      350/NV3500 5spd
      2014 Chevrolet Malibu LS
        Stock gasket modified is how I do it.
          Thanks guys for everything. I have one more question. I am doing a 3500 top swap on my 3400 and am having a little trouble trying to figure out how to use the valley gasket from the 3500. Do I just trim to fit? Its the gasket that goes between each head in the front and back.
            You can cut the little tabs off the orange ones and use sealer on either side, but it's just as easy to handle it like you would the 3400 and use straight sealer.
