wideband o2
  • wideband o2
    got a wideband o2. which o2 sensor do i want to replace with the wideband.
    the upstream or the downstream. im pretty sure you want to do this to the downstream one, but im just double checking.
    you don't replace either. you put a new o2 bung NEAR the first 02
    Mike 60degree addict.
      This was a question for me as well. I was under the assumption you could wire in a wideband in place of one of the stock narrow band to be able to use it with HPTuners and other tuners? Guess I read the wideband instructions from wot-tech wrong?
        An Innovate LC-1 WBO2 has a narrowband output that can replace the front o2
          Thank you very much! I looked over the instructions again and saw that.
