86 2.8L MPFI to Carb swap
  • 86 2.8L MPFI to Carb swap
    Hi Guys,
    Been searching but can quite pin the answer. Will the earlier S10 2.8 carbed intake manifold fit on my 86 2.8L Camaro block? I'm stuffing the 2.8 into an MGB roadster and do not want to mess with the FI wiring and fuel system. The local pull-a-part has several of the 2 barrel 2.8s. And dont want to waste $$$ if it wont work. Seems it should, but just want to make sure.
    Thanks
    Yes, all iron head manifolds are compatible with all iron heads.
    Droid via Tapatalk
