What do i need/can do?
  • What do i need/can do?
    Ok i'm going to be picking up a 10:1 flat top 3.1 short block from a friend and i was wonding if i can swap to a 7730ecm in my fiero using a Wot-tech. 3500 trigger wheel?
    Anybody know if i can it would help me out alot thanks.
    If not can i use a carb setup to get good air to the motor using a 4.3 carb?
    If you know how to can someone point me in the right direction for this please?
    Thanks
    Plenty of 7730 swap info over at Pennocks. As for carb or no, that is a decision you should make going in and then stick to it. Winters up in cow-town can be pretty harsh so I'd lean towards fuel injection if that is in your budget. Once you have a plan, then the research begins in earnest.
      Need to figure out something on the 3500 trigger wheel
        bump
          what Gen would this motor be? and why not go for a 3500 if your going through this much trouble, you'll be going over the same hurdles to get it running on EFI
            I'm not looking for a 3500 swap and the whole motor with 0miles on it is only $450 bucks. and idk what gen it is but it is a flat tapped cam.
