External fuel pump to run the camaro 3.4L?
  • External fuel pump to run the camaro 3.4L?
    Can anyone recommend an external fuel pump that generates sufficient flow and pressure to run the 3.4L that came in the Camaro? I am installing it in my MG and don't want to modify the fuel tank to do an internal. If you can't recommend a specific unit, do you know the specs required by the injection system?
    Thanks,
    Paul
    well, the FPR is going to clamp down until 43.5PSI at static, then it will open up more based on how much fuel is being used compared to how much is flowing from the pump...
    if you lookup a fuel pump from a 3.4 f-car on autozone, i believe it will give the factory flow rating as well, or at least what the stock replacements do.
      As long as the pump will support the pressure required I bet almost anything on the market will flow enough. Holley, Carter, Aeromotive are common brands.
