'91 Sunbird 3.1L - Interference Engine?
  • '91 Sunbird 3.1L - Interference Engine?
    Engine died in middle of intersection.
    Tried to turn it over, and it just turned over like there was no compression. I'm not a pro, but the sound is pretty obvious, and that's the first thing that came to my mind, and my brothers when he heard it.
    Anyway, changed chain and cam gear (don't think it needed it, but i was in there anyway). Chain Guide was chewn away completely on the right side, old chain was 1/4 inch longer than the new. Dropped the pan and cleaned all the crap out.
    Installed new guide, gear, chain, and engine turns over with the same "higher speed" sound as when it died (disapointment).
    I've had conficting answers, but I gotta believe that the engine is an interference type, and that I bent some valves big time. About to run compression tests.
    Anyone know for sure?
    Thanks.
    PS: the 3.1 is distributorless, and I'm damn sure I've got the timing marks right.
    Yes, its interference
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
      Thanks, I guess I had to figure that it was, but was in denial
      I just couldn't find any substantial documentation to indicate that it was.
      Mark.
        Alot of times people get lucky and no damage occurs. Take the valve covers off and do a visual inspection. Hand rotate the engine and see if all the valves are moving up and down. Be sure none are stuck in the open (down) position from being bent.
