3900 flow
  • 3900 flow
    Why are the last 3 cylinder so low?
      1st 3 are intake, last 3 are exhaust side.
        i thought there already was a 3900 flowsheet???
        oh well, more information for DD2003 to play with.
          Well... now i know what's going to replace my 3500 one of these days..
          Just need to get those exhaust numbers up to 200 CFM
            These are stock flow numbers?
              Yes
              and the intake flow is like 20 CFM higher than my ported 3500 heads
                200cfm at .300" that's insane for stock 2v heads.
                Well, technically you should see 75% of intake flow on the exhaust for naturally aspirated.
                  Those are stock numbers off my bench. Its 72% avg I/E ratio, but that is .050 to .600. The exhaust should be higher, and that ratio John posted is just a guide. The better the exhaust flows, the longer you can let the power stroke go before opening the exhaust valve.
                    I always heard 80% for N/A.. Either way, those are crazy numbers.
                      Yes, it's a guide, just like the throat vs. valve area etc. Besides, those numbers will change a lot with manifolds on.
                        holy snit. A 400 Pontiac RAIV or SD455 head doesn't flow like that!
                        Jeff Ianitello
                        Engineered Performance
                        Atlanta, GA.
                          well, neither do these heads Its really close, but I am going to flow a couple more heads before I post the new numbers. I know better... oh well. I had taped the intake ports but the tape wouldn't stick, even at .050" lift on the valve I was measuring so I thought the ports were sealed that well by the valves. Once I get higher lift, the tape will stay, barely with the suction.
                          This time the same head flowed 195-197 at .300 and mid 250s max. Still impressive, but the high lift doesn't keep on going like it shows on the current sheet.
                            DOH!
                            I always run tests consecutively with checking in between.
                            Try the silver air conditioning tape, it will hold.
                              I run consecutive and normally use duck tape, but I have this blue masking tape and its weaksauce.
                              This head reflowed the same today as yesterday so I am going to go grab another stock head to verify it.
