oil leak only while running?
  • oil leak only while running?
    can some one help me with diagnosing this problem?
    Without much information to go on, that could be anywhere. It could be the distributor o-ring, a head gasket, a valve cover gasket, a LIM gasket, an oil pan gasket or a timing chain cover gasket...
      well it leaks from some where right above the starter sylinoid and when coming down it hits the starter but that was all i could see.
        Then that would either be the front valve cover or the front head gasket leaking. I would be more on the valve cover, but you really need to clean it really well if you have a hard time finding where it's leaking from so you can see where the trail starts.
          yeah one of my friends also told me it could possibly be my rear main?
            Depending on the vehicle, it could also by the oil pressure sensor.
              its a 96 monte carlo
                If it were the rear main seal, then it would be leaking from where the trans and the engine bolts together, out of that plastic inspection cover.
                Typically that doesn't go out though... its more likely the valve cover, or Oil pressure sending unit as bszopi said.
                  I wasn't even thinking about that. Good catch, Brad
                    Sounds like oil pressure sensor should be right out the front near the oil filter, these usually leak pretty good when the engine is running, these car also leak fron the intake manifold gasket the vally as they call it the oil pressure senson is round and about 3 to 4 inches long depending on yr/ also ck you oil filter
                      idk im not that worried about the car if i just keep oil in it it should be fine right?
                        Why did you ask if your not worried about it or even planning on fixing it?
