Where to find parts?
  • Where to find parts?
    I am having problem getting stock replacements parts for V-6/2.8/3.1/ 60 degree. None of the dealers has anything to help me, could anybody help me find stock replacement parts and parts numbers. I have try GM Direct and they said they couldn't help.
    What kind of parts are you looking for? That may help us in providing you with a place to look.
      V-6/60 2.8/3.1 engine parts
      I need parts catalog for parts from top to bottom inside and out. Heads, Cams, Lifters,Value Springs Timing gear and chain, Good gasket sets, Two barrel Carb Intake,Value Covers,etc.
        Fel-Pro sells all the gaskets in and top and bottom end kit.
        Federal Mogul sells all the bearings and pistons and stock valve train parts.
        Comp Cams sells every performance valve train part. Including the timing chain.
        GM also sells everything from the dealer.
        You will never find a stock intake, even from GM just go to the junkyard. For the valve covers you can use the stock tin ones from the cars and trucks but the aluminum ones from a Fiero are much stronger, lighter and better looking.
