Is This common????
  • #16
    Bump....any ideas??????
    • #17
      Im am not up to date on the new codes. Do you have definitions?
      • #18
        The only code present still is the P1374 its 3x reference signal or something like that. I think i might put a front crankshaft position sensor.
        thanks,
        Jr
        • #19
          3x reference signal would have to do with the 7x crank sensor you mentioned you already replaced. I would look for possible nicks/cuts in the wire going from the crank sensor to the ICM.
          • #20
            (7x) or (3x) is the one in the block. Are the twisted wires damaged coming off of it?
            24x would be the one behind the crank pulley.
            Doh, should have refresehd the page before replying. Brad beat me.
            • #21
              Refreshed the page?!?!? I beat you by 8hrs!!
              • #22
                Just got back from a business trip. I replaced the sensor on the side of the block and also replaced the harness and its still doing the same thing. Hard to start, has a miss at idle, but runs fine other then that. Any Ideas?...thanks guys you've been alot of help.
                • #23
                  Yeah Brad, I had the window open at work and didn't get to check back till later... LOL
                  Is the FPR leaking fuel into the vacuum line? What's the pressure at idle with and without the vacuum on it?
