Manifold
  • Manifold
    When you put an intake manifold on a 3.1, do you put the gasket on dry and do you put oil or anti-seiz on the bolts? I found out you have to remove the push rods to get the gasket on, and put a bead of black RTV on the ends.
    You don't have to use anything. But considering the bolts go into aluminum a small dab of antiseize is a good practice.
