oil presure location
  • oil presure location
    i am putting a 3.4 into a opel gt. the stock oil filter adapter has the hole for the oil presure sending unit or line on it.because of clearance issues i needed a oil filter adapter from a earlier v6 block that is not tapped or plumbed for a oil presure sending unit or line. I cannot find any locations on this block . any ideas anyone??:
    There is one one the oil filter mounting boss. It is plugged with an 1/8" NPT plug. Do you know what adapter you have? There were different versions in different vehicles. The ones in S-10's, Camaro's and Trooper/Rodeos were all different but they were all RWD applications.
      oil adapter
      the adapter i-m using came of a front wheel drive. the adapter comes off the engine then the filter drops vertical from there.i-ve had several but for clearance this is the one that fits.
