Block casting #
  • Block casting #
    I AM TRYING TO ID A ENGINE. not sure if its a 2.8 3.1 or 3.4 the casting # on front of the block is 10118608 can anyone help? thanks
    Is there a large letter on each side of the block @ 2" tall? It should be high on the block above the opsu. If you have it what letter is it?
      Punching it into Google comes up as a 93-95 RWD Camaro 3.4L engine.
        Then it should have the letter "F" on the side
          both sides of the block have the letter F
            WHAT DID YOU PUNCH INTO GOOGLE? i tried earlier but got no where
              i punched in 10118608 block into google and the 4th link down was a PDF to a bunch of GM casting numbers. I'll find the link:
              www.enginepartswarehouse.com/enginecatalog/GENERALMOTORS.PDF
              somewhere a few pages down in that it mentions the casting number next to the Camaro 3.4 listing.
                letter F
                Do all 3.4's have the letter F on the side of the block? If so is it stricly in the Camaro or in various cars? The one in my Camaro has a number at the back horshoe area of the block and has a s in the serial # it also has the big F
                on both sides block so i'm assuming it is a 3.4?
                shrek
                  RWD 3.4's have the "F", yes. All the differnt type of blocks have a letter on them that makes them easy to identify
                  EDIT: Except the 3500, it say's "3.5L" on the side, not sure about the VVT stuff.
                    I not saying your wrong but I thought there was a "C" on the side of them?
                      Ah, why yes there is not that you bring it to my attention They just moved it to the bellhousing area.
                      I have 3 3500 blocks sitting here next to me right now
