ok which one is it for oil press
  • ok which one is it for oil press
    which plug is the one for the oil pressure. im looking to bump mine up about 5...whch means one 1/4" shim right? but which hole does it go into...?
    btw 02 3400
    Why do you need 5 psi? I don't know anything about adding a shim to give more pressure. Springs yes, shims no.
      just looking to add a little more press, bc i was going to look into putting those oil squirters on a block...the "shims" are normally washers that you put to increase pressure from the pump
      basically like a valve spring shim does...compresses the spring a little more
        ok, so it is the spring you wanna modify. that makes more sense to me. As for the oil squirters, maybe we should compare the 3500 oil pump to the 3400? Maybe you already did?
          wow, you catch on quick...maybe i did. although i like the idea of the HV pump that melling makes...i dont like it that much when you hear the horror stories. you can now get the hv 3500 non vvt pump from melling also. i just saw it when i was looking around at oreillys yesterday. i need to look at the 3500 one closer though and see if anything is diff, my mind gets fuzzy over the weekend
            someone...anyone?
              does anyone have any input?
                Nope...
