problem removing cam on a 3400
  • problem removing cam on a 3400
    Im trying to remove my cam but it pulls out about half an inch and block at about half a turn...can't get it to pulls out more...any ideas...oh yes I removed the lifters before someone answer me this
    Did you remove the oil drive plug?
      other than removing the oil drive gear, just be careful when pulling it out you dont want to trash the cam bearings.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        Did you remove this thing?
        Drivers side of the car between the engine and transmission under the exhaust crossover. If you didn't remove this (which is the oil pump drive), then that is probably what is holding it in.
        Taylor
        1998 Lincoln Mark VIII
          ^^^^ Why didn't I think of that? So simple!
            Pwned
              more like why didn't you think about posting a picture of it just in case MitchPower is a beginner with the 60 degree engines, and does not know what the "oil drive plug" is.
              Or more like why didn't you tell him where the "oil drive plug" is located in case he is a beginner to the 60 degree engines?
              I know I am stating the obvious, but if it was something so obvious, then why is he asking for assistance?
              Taylor
                Pwned X2.
                Welcome to the 60* community though Mitch . But that should be what your problem is.
                  Well I guess I was really waiting for a response from the guy, but thats just an excuse for being lazy. I really was complimenting you on your post, whether he responds or not you are fairly sure he got the information needed.
                  Let us know how it goes Mitch.
