I have 97 3400 LIM/UIM/ with rail, injectors, FPR... before I strap the stuff on the 3100 should I just change back to my 3100 injectors and FPR. it should be noted that the 97 3400 injectors are about the same as the 99/3100 injectors... im just not sure about the FPR, if I should use the one I already had... need answer fast!!!
FPR question
pre-99 stuff is all the same
But it might be wise to re-use your injectors if the other ones have been sitting for a while. They might be clogged/sticking. If they dry out they don't do so well.sigpicNew 2010 project (click image)
the fuel pressure is the same 43psi for pre 99 its 55 psi for 00+sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
arent the 3100's like 17 lbs and the 3400 ones 19 lbssigpic
99 Grand Am GT
