intake gasket question
  • intake gasket question
    I finally found some cheap enough 3400 manifolds, and before I throw them on the 3100 (97 Monte Carlo) I'd like to be sure of which gasket kit to go for... for a 3100 or a 3400? I know it seems obvious.. but i want to be safe.. thanks
    You should match the gaskets to the heads or the lineup pins won't work.
      ok then. now if the gaskets match the heads... how does the 3400 LIM port line up to that 3100 gasket??
        Close enough. It's not 100% perfect, but it works. I'm proof of that.
          thanks for the answer Issac
